How to repair & solidify STEP file in Creo 3.0?
adeshmukh
Can anyone tell me how to repair & solidify STEP file (surface part) in Creo 3.0
AD
You have to go through the cryptic means that Import Data Doctor (IDD) allows you to modify the import geometry (surface and wireframe data).
It does come with decent analysis features.  Interpreting and healing the error is another story.
Searchable on the forum or in help.
Some have great luck with it; others - not so much.
2 REPLIES 2
Here best tutorial. For a basic use of IDD you don't need to use all functionality described there.
Anyway you know all command and so you can play with it.
