Hi..
As in WF5.0 there was an option to create pipe section through all points, But i am not able to get it in Creo2.0.
So please can i know how to create pipe section through all points.
Prashant Pandarkar
You need to select the datum point feature instead of selecting one of the points in the graphics window. The feature doesn't show up if you "pick from list" for reasons unknown to me. You can either select the feature from the model tree or you can set your filter at the bottom to "Feature" and then select from the graphics window.
Thank you very much. Its working for me.
Prashant Pandarkar
