Hi there,
Every time I set a tolerance, I have to set the tolerance table to ‘None’ from the default type ‘General’, it’s really inconvenient, is there a way to set ‘None’ as the default type?
in https://www.ptc.com/en/support/article/CS237247 document you can find information related to your question.
Hi, Martin Hanak,
Really thanks, work like a charm!
Lee
