How to split this IGES "assembly" that imports as single part
ssharma-2
Hi all,
I want to split this IGES assembly in single single parts, is there any way.
Shashank Sharma
Inoram
(To:ssharma-2)
I imported as an assembly and it is still one piece, so it looks like they exported it that way. So the only why I know of it to make copies and delete out all the surfaces except for the piece you want. Which is almost useless here as it appears to be missing surfaces.
I would say ask who ever you got it from for an assembly in STEP or X_T or whatever.
TomD.inPDX
(To:Inoram)
I know that some companies only provide single level iges files to protect reverse engineering.
Funny thing is that they rarely take the time to make it an envelope model.
rli
7-Bedrock
7-Bedrock
(To:TomD.inPDX)
Hi Antonius,
Can you share with me on how to make the assembly to an envelope model? Sometimes I need provide to customer the single level iges for them fit check, the inner features must be removed as to follow company rules, but I didn't find an easy way to quick remove the inner features to generate a single level model.
Your help is really appreciated!
Rick
TomD.inPDX
(To:rli)
Search for "shrinkwrap" in the help section. I remember once following a tutorial on the process but cannot find it readily. I am certain someone has some links to get you a guide on how to use this feature.
