I've created a custom screw in IFX and all works great except I get 1 error when placing the screw. When I select the hole, head and nut reference and click OK to place screw, I get an error saying......
What does this mean? I'm new at customizing IFX and can't figure this issue out.
Below is a portion of my .dat file.
!Socket Head Cap Screw
!McMASTER-CARR
SCREWTYPE 01
UNIT INCH
SURFACE 392
AXIS 427
SYMBOL STRING DN LG S DK K SH_HEX_DEPTH SUPPLIER_NAME SUPPLIER_NUMBER
INSTANCE STRING DN LG S DK K SH_HEX_DEPTH SUPPLIER_NAME SUPPLIER_NUMBER
SHCS_0-80-x-0_064 #0-80 0.060 0.064 0.050 0.096 0.060 0.025 McMASTER-CARR 92196A047
SHCS_0-80-x-0_094 #0-80 0.060 0.094 0.050 0.096 0.060 0.025 McMASTER-CARR 92196A051
SHCS_0-80-x-0_125 #0-80 0.060 0.125 0.050 0.096 0.060 0.025 McMASTER-CARR 92196A052
SHCS_0-80-x-0_156 #0-80 0.060 0.156 0.050 0.096 0.060 0.025 McMASTER-CARR 92196A053
SHCS_0-80-x-0_188 #0-80 0.060 0.188 0.050 0.096 0.060 0.025 McMASTER-CARR 92196A054
SHCS_0-80-x-0_250 #0-80 0.060 0.250 0.050 0.096 0.060 0.025 McMASTER-CARR 92196A055
SHCS_0-80-x-0_281 #0-80 0.060 0.281 0.050 0.096 0.060 0.025 McMASTER-CARR 92196A416
What is the "INSTANCE row for? The template .dat has it in there and I was wondering if I even need that?
it seems like that the fastener has some unresolved relations in the .prt file.
Please make sure that the param_relations.txt create a correct relation set inside your fastener with the given parameters.
See also: Relation Files (ptc.com)
