IFX fastener dowel pin c'bore size Creo 7
GP_10379774
Creo7 When using the IFX fastener dowel pin counter bore option it only allows you to put a through hole in smaller than the dowel pin. I would like to flip the counter bore around so the counter bore is larger than the dowel .
Example: On a 1" thick plate Ø.2497-.2500 thru, C'bore Ø.281 x.5 deep. This way the press fit isn't through the whole thickness of the plate.
This is not possible at the moment.
Can you send a small example for this.
Maybe we can add this as an enhancement for one of the next releases.
Thanks.
Oliver Gräbner
B&W Software GmbH
