IFX - problem with custom parameters and relations
durgela
Our customer was create a start_mdl_cfg file with custom parameters and param_relation. txt file with relations. All parameters and relations are created corrrectly in profiles, connectors, etc, however, it doesn´t work while I creating screws, pins and washers in AFX in Creo Parametric 2.0.  Answer with PTC is, that a start_mdl currently does not work for parts of smart library and when I need to add parameters, so i need to opening template models with Creo and adding parameters manually.
Can you help me a better solution? I need a designated parameters. Or you can add this functionality in next version of IFX in Creo Parametric 3.0 and next datcode in Creo Parametric  (AFX module) 2.0?
Good news: We add this functionality in Creo 3.0
We now have an ifx_start_mdl.cfg for IFX. Refer to the Creo Parametric Help Center
The ifx_start_mdl.cfg Configuration file
4 REPLIES 4
this is a good idea. We think about to add this functionality to one of the next IFX 3.0 releases.
To track this idea can you please move this idea to the new group Intelligent Fastener Extension - IFX
Oliver Gräbner
B&W Software GmbH
TomU
(To:durgela)
Ryan Kelley
Please move this to the IFX Group.
ryankelley
(To:durgela)
All set.
Thanks!
Oliver Gräbner
B&W Software GmbH
