I see that creo 7 will import native solid edge files - it is in the pull down options list when one goes to open a file. The problem is that when the import is completed (assembly file opens in creo) I am not seeing any parts in the model tree.
Is there an additional app that I need to install, or is the way the original file is being saved?
can you upload some data for testing purposes ?
Please take a look at this. Am I missing some supporting files? Every time I go to import .asm files, there are no parts in the assembly
Sorry - take a look at this one.
when I open PRG87A600000-OP250 CONVEYOR MODIFICATION.asm in Creo 7.0.2.0 I can see that it depends two subassemblies. These file must be present in the same directory.
