Quisiera saber si hay alguna manera de exportar algunos templates desde CATIA a CREO o si se deben de hacer desde 0 una vez en CREO para guardarlos y después usarlos.
Maybe you mean drawing formats. You can export them in DXF format but any "smart" things it does in Catia will NOT transfer over.
Yes, use STEP or IGES to export your model from the originating CAD system.
thanks but Im talking about the templates, no the CAD, i want to use some templates from CATIA in CREO, for the 2D blueprints.
Like Stephen said you can export the format as DXF to import, but the parametric driven data of the format or drawing template must be recreated in Creo.
Translated
"I would like to know if there is any way to export some templates from CATIA to CREO or if they have to be done from 0 once in CREO to save them and then use them."
Moving this to Creo for the most eyes.
Best,
Toby
