Is there a way to regenerate the part model and assembly using ModelCHECK SAVE mode?
MS_10437608
6-Contributor
is there a way to confirm whether the model is regenerated or not?/ family table is verified or not?/relations is verified or not? using the ModelCHECK save mode.
1 REPLY 1
ModelCHECK SAVE mode doesn’t perform regeneration, it provides checks to flag issues that may require regeneration or further attention. You can confirm if the checks are passed through the generated ModelCHECK reports. For enhanced regeneration, you’d use the REGENERATION mode or manually ensure regeneration outside of ModelCHECK SAVE mode.
