Is there any option to hide solid and surface active ???
can you specify your question a little?
It is possible to hide surfaces and also the entire solid (SolidGeom) within a part
Yes, create a new layer and add "Solid Geometry" to it. Hide that layer.
Ravi,
in Part mode solid geometry can be suppressed, but not hidden (like datum features).
Martin Hanak
Martin, this is no entirely true, single solid features can not be hidden in part mode, the entire solid can be hidden! ...as i stated above and Tom was kind enough to capture...
That is true
Martin Hanak
