3-Newcomer
July 26, 2024
Keep parts original names when importing STEP files
  • July 26, 2024
  • 13 replies
  • 4980 views
Hello there, I've got a problem I can't get my head around and I hope some of you have got a suggestion for me.
I'm trying to to import a STEP file (an assembly) into Creo and the problem is that all the parts name get changed and doesn't stay the same as per the original file. The get renamed like MG_100000 etc.
Does anyone know how to make Creo to keep the original part name?
open STEP in Notepad. Can you find original names in the file?
3-Newcomer
July 26, 2024
Hi Martin, yes the step file has names in it.
KenFarley
If that text hightlighted is what the part name is supposed to be, then you have a problem, because that's not a valid file name for Creo. You can't have spaces in file names in Creo.
From the support page about files:
"You cannot use brackets, such as [ ], { }, or ( ), spaces and punctuation marks (.?!;) in file names."
So, the importer probably sees these file names and assigns them new names during the import to comply with these restrictions.
I had a similar issue with one of my suppliers and the solution in that case was to ensure the STP file was exported with AP214 format.
