Changing component parameter "linenumber" for all instances
I have an assembly that is broken into several different simplified representations. I want to use a BOM table in my drawing for consistent balloon numbering.
The best way I see to do that is to use a component parameter "LINENUMBER" in an assembly that will store the line number for a bom table in every instance simplified reps.
I've entered Linenumber as a component parameter for a few components, but a problem I run into is that when I have instances of hardware I have to enter this parameter individually for all the hundreds of screws and washers.
Is there a way for me to enter the component parameter for all instances of a component without having to work with Windchill?
Creo 7.0.7.0
