There are several way to copy surfaces depending on dependecy and relationship.
Option 1:
1) Genereate a step file using surface only and import to new part.
2) Remove any surfaces that you don't need. (This is best when you don't want relationships).
3) Note:(At this time you can also copy and paste but it will cause dependecies)
Option 2:
1) Copy the surfaces on the model and paste.
2) Open up all ref
3) copy the feature (paste) from one model part to the other.
Option 3:
1) Export the curves only and re-import - Then re-create surfaces in the model.
Good luck - More options are more complex. (Style - re-create in asm mode).
Thanks & Regards
Paul Lalinde
Mechanical ENGR STF PRNCPL
Advanced Data Capture
Motorola Solutions, Inc.
motorolasolutions.com
O: 631-738-3592
M: 954-410-8062
E: Paul.Lalinde@motorolasolutions.com
