I have two .step files in my assembly model that I am showing on a drawing. When I do a section view, the linestyles of these parts in the assembly become magnified to show many more line segments. How can I change this? See picture below.
Your step file is a surface model, not a solid model. You have a couple of options.
1. You can convert the surface model to a solid model which may be difficult.
or
2. You can add quilts to your x-section by selecting "include all quilts" when creating the x-section under the options tab.
You'll also have to make sure in your view properties on your drawing that HIDDEN LINE REMOVAL FOR QUILTS is set to yes.
or
Thank you Stephen, that did the trick!!
