MPI Service is not activated
SS_10704479
8-Gravel
I am using Creo Parametric Release 4.0 and DatecodeM010
Dear PTC Support team
What is MPI Service? why it's not running?
Is in EMX module or Analysis Extension?
Please see attached file.
4 REPLIES 4
Article - "MPI service installed with Creo 7.0.4.0 is not recognized by Creo Mold Analysis solver in Creo Parametric": https://www.ptc.com/en/support/article/cs345197
Hello @SS_10704479,
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
did you select MPI item during Creo installation? If not you have to install Creo from the scratch.
Martin Hanák
