Machine bend of individual pipe
ErikClacey
I have made a pipe with the Pipe module and have split it into manufacturable pipe sections. I now want to make drawings of each section and show the machine bend table in a table.
How do I do that?
If I open up the part and make a drawing of it, I can't access the saved machine bend table, as it was made in the assembly. Piping only works in the assembly mode, so I can't make a machine bend table within the part/section. Alternativel I can make a view state in the assembly with only the pipe section that I want, which I can put in a drawing. If I then make several different machine bend table analyses and save them in different names (for the different pipe sections), I get all of them in the same repeat table in a drawing. How can I filter or remove the ones (machine bend table analyses) I don't want in the current drawing?
2 REPLIES 2
I have the same problem. Bend tables can be saved as separate reports for each pipeline, but I cannot seem to differentiate between those saved analyses in the repeat region - all tables are listed. Any special filtering in the repeat region to fix this. Have you found a solution, Erik?
Yes, this seems to be something that PTC should improve upon. In the meantime, I did find a way.
First make a drawing with the assembly, but don't add a graphical drawing of it to the sheet. Instead add a drawing model and now select the tubing part that you want. Add your views and machine bend table etc.
Now set a filter to the bend table repeat region to only show information for your single tube that you just added. For example:
&asm.mbr.pipe.segment.solid_name == 200-100-231 will only show data for a pipe with this name
I guess you can also add * if your names only have a few unique identifiers in a long name.
