Marking Text in an assembly-exploded view
JesseFischer
I sketched some text in an assembly tied to one of the components. Is there a way to get it to explode--following the component referenced? Do you have other suggestions?
Its better if you use annotation feature in asembly. Type your text in and attach it to desired part. Explode will work fine then.
If you still want sketched text then you must make that sketch in part and then it will move with it in explode.
