Measure cable minimum bend radius?
Are the claims in the following statement correct? Specifically, is the statement underlined and in bold correct?
Creo manages the bend radius of the CAD model by applying the minimum bend radius from the spool onto the cable geometry. Networks are simply helper aids for routing. They do not control bend radii. When Creo places cables, it tries to follow the Network first. But in some scenarios, where the network is tighter than the spool's minimum bend radius, it will allow the cable to depart from the Network. Essentially, what you're seeing is Creo applying the minimum bend radius of the spool onto the 3D cable geometry. Therefore, you don't really "measure" the minimum bend radius so much as enforce the minimum bend radius. Any measurement that would be taken would equal the value of the minimum bend radius of the spool.
Thank you!
Devin
