Are Merge/inheritance feature accessible with a Creo Essential license ?
I use this function in parts for years but recently we change our license "Creo Advance Design" for "Creo Essential". Since this the buttons are grayed out...
Is it a problem with my creo install or a license issue ?
Thanks in advance.
Merge/Inheritance does require the advanced assembly license. Creo Essential does not include Merge/Inheritance.
Ok Thanks...
Last question. Here are the different modules between creo "Essentials" and "Advance".
https://www.ptc.com/en/support/article/CS298294
Whitch module enable the Inheritance functions ? "Assembly", "Process for assemblies", other ?
Is it possible to buy only this module separately ?
Thanks in advance.
You can buy Creo Advanced Assembly Extension separately (not part of a package) if you wish.
