Anyone know why my principal datum planes won't display as Top, Front, and Right but instead show up as DTM1, DTM2, and DTM3?
Also, how do I display datums (planes, points, etc.) in the model browser in Assembly mode?
Thanks.
[Using Pro/E Wildfire 4.0]
By default, if you create an empty part and then create the default datum planes, they get the names DT!, DTM2 & DTM3. If you want them named, you need to:
