I am using Creo Parametric Release 6.0 and Datecode6.0.0.0
1. In MBD, while publishing only selected view, in PVZ file, all view getting published.
2. In MBD, Before publishing, sketch is hidden but in PVZ all sketch are visible.
3. In MBD, Location and size of dimension get changed after publishing in PVZ.
Are you doing the publishing on a separate computer? If so check the config.pro settings and the publishing recipe file for the right settings.
Dear BenLosli,
I am opening MBD .PVZ file in same computer where I am creating it. Still I am facing dimension position & its font getting changed. Sometimes even arrow for dimension also get changed.
And all views are getting published although I have chosen not to publish some view in VIEW Manger.
