Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
I would like to see if anyone else has see this andif anyone has a solution.Everytime I load any assemblies I notice that the modelscolors change. I am using the companiesstandard Appearance file. I'm at a loss as to why this is happening. I have even created my own local appearance file but the colors still keep changing. I'm thinking that it might be a graphics card problem but I wanted to get other opinions.
I would verify that your config.pro file points to the proper appearance file on startup. Otherwise, the default appearance file will load up starting Pro|E.
