Model Colors Changing within assemblies
jhengel
I would like to see if anyone else has see this andif anyone has a
solution.Everytime I load any assemblies I notice that the modelscolors
change. I am using the companiesstandard Appearance file. I'm at a loss as to
why this is happening. I have even created my own local appearance file but the
colors still keep changing. I'm thinking that it might be a graphics card
problem but I wanted to get other opinions.
msecco
(To:jhengel)
Hi John
If you apply a color to a component in assebly mode this component will have
a different color in part mode. This is the default in Pro/E.
Regards
I would verify that your config.pro file points to the proper appearance
file on startup. Otherwise, the default appearance file will load up
starting Pro|E.
Sincerely,
Neal Rosenblum
Geometrix Engineering, Inc.
201 N. 13th Avenue
Hollywood, FL 33019
