In our office, we recently updated all the systems to M050 from M040. During M040 versions, all systems were running the model check correctly. After the upgrade, only few systems are working fine and the others are not running the model check in any mode. MCDIR is set correctly in the environmental variables. How we could fix this.
start commands are .psf files located in Creo4_loadpoint\Creo 4.0\M050\Parametric\bin directory. Default name is parametric.psf. License assigned to .psf file is specified in ENV=CREOPMA_FEATURE_NAME= line.
M040 or M050 of what version, creo3, creo2, creo4?
MCDIR has been replaced by another variable recently. Check the documentation, I found this CS article.
Its Creo 4.0 M050. And when I save my file, it flashes a quick message 'Option ModelCHECK is not available'. In some systems using MCDIR variable, it works perfectly.
'Option ModelCHECK is not available' message prbably means that your license does not contain ModelCHECK. Please check it.
But how it is possible that one day everything is working fine and the next day when I restart Creo, I'm facing these issues. How to check what license the creo is using. FYI, our licenses are kept in a network server.
