11-Garnet
August 1, 2018
Model check not running after M050 upgrade.
  • August 1, 2018
  • 3069 views
In our office, we recently updated all the systems to M050 from M040. During M040 versions, all systems were running the model check correctly. After the upgrade, only few systems are working fine and the others are not running the model check in any mode. MCDIR is set correctly in the environmental variables. How we could fix this.
    Best answer by MartinHanak
    start commands are .psf files located in Creo4_loadpoint\Creo 4.0\M050\Parametric\bin directory. Default name is parametric.psf. License assigned to .psf file is specified in ENV=CREOPMA_FEATURE_NAME= line.
    M040 or M050 of what version, creo3, creo2, creo4?
    MCDIR has been replaced by another variable recently. Check the documentation, I found this CS article.
    https://www.ptc.com/en/support/article?n=CS57367
    cloni11-GarnetAuthor
    11-Garnet
    August 2, 2018
    Its Creo 4.0 M050. And when I save my file, it flashes a quick message 'Option ModelCHECK is not available'. In some systems using MCDIR variable, it works perfectly.
    'Option ModelCHECK is not available' message prbably means that your license does not contain ModelCHECK. Please check it.
