The easiest fix would be if you find that the option create_fraction_dim is set to yes. You'd have to figure out how it got set that way, but at least you'd know.
Other than that, I don't have any idea.
Check it with File -> Options -> Configuration Editor
(I'm on Creo 4.0, so hopefully this is the same setting and means of changing it for you)
Does it actually display 3/16 or 0.1875?
It displays it as 3/16
Sounds like your dimension format is set to fractional. Is this happening for all dimensions, even newly created ones, or just to existing dimensions?
It looks like changing the create_fraction_dim value fixed the problem.
Thanks for the help.
