Model dimensions rounding to nearest fraction
CS_7281178
2-Explorer
I am using Creo Parametric - Release 8.0 (connected) 8.0 8.0.0.0
When I am modeling a part it is rounding my dimensions to the nearest fraction. So when I type in 0.1943 it rounds it to 3/16. I looked in the configuration editor but nothing stood out.
The easiest fix would be if you find that the option create_fraction_dim is set to yes. You'd have to figure out how it got set that way, but at least you'd know.
Other than that, I don't have any idea.
Check it with File -> Options -> Configuration Editor
(I'm on Creo 4.0, so hopefully this is the same setting and means of changing it for you)
TomU
(To:CS_7281178)
Does it actually display 3/16 or 0.1875?
CS_7281178
2-Explorer
(To:TomU)
It displays it as 3/16
TomU
(To:CS_7281178)
Sounds like your dimension format is set to fractional.  Is this happening for all dimensions, even newly created ones, or just to existing dimensions?
It looks like changing the create_fraction_dim value fixed the problem.
Thanks for the help.
