Model to Help 5th Graders Understand PTC Coordinate System
torme
I've made the following model with which I hope to explain the PTC coordinate system to 5th Graders.  I've succeeded only in confusing myself.  Maybe you can help.
The file is attached.  Created with Creo Parametric 3.0 M070 Academic.  I think this a right hand system as pictured,  I've extruded X+, X-. Y+, Y-, Z+ and Z-.  I want to extrude (20mm) FRONT+, FRONT-, TOP+, TOP-, RIGHT+ and RIGHT_ on the planes  I presume that FRONT+ is on the Y+ side of the FRONT plane.  Am I on the right track?
It seems to me that the default system in Creo Academic is a left handed system!!!
32 REPLIES 32
torme
(To:psobejko)
Fortunately you can do a lot in Creo Academic without understanding the Right, Left etc nomenclature.
I'm trying to learn Creo using
This is not appropriate for 5th graders.  Chapter 5 entitled "Datum" is almost unreadable.  It does give you some insight on how to edit.
On Day 1 I intend to teach how Creo toggles back and forth from 2D to 3D.  You never really leave 3D.  In the 2D case you look straight down some axis so it looks like 2D.
It would be nice if the planes were labelled XYZ plus or minus.
Front       XZ+
Back       XZ-
Top        XY+
Bottom   XY-
Right      YZ+
Left         YZ-
Whether I should teach 5th graders to work with user defined coordinates rather than Creo default is a good question.  I'll have to think about it.  At some point I need to discuss the historical reason for PTC coordinates.
First they need to know about the right hand rule and orthogonality.
Maybe Day 365
MartinHanak
(To:torme)
it seems to me that datum plane names are only text strings. User can set naming convention according his needs. Also view names are only text strings and user can interpret them according his needs. Terms as Front, Top, etc. are understandable when doing model reorientation.
  • model surface selected as Front reference will be oriented parallel to display screen with its normal pointing "to the user"
  • model surface selected as Back reference will be oriented parallel to display screen with its normal pointing "away from the user"
  • model surface selected as Top reference will be oriented perpendicularly to display screen with its normal pointing "up"
  • model surface selected as Bottom reference will be oriented perpendicularly to display screen with its normal pointing "down"
  • model surface selected as Left reference will be oriented perpendicularly to display screen with its normal pointing "leftwards"
  • model surface selected as Right reference will be oriented perpendicularly to display screen with its normal pointing "rightwards"
MH
Martin Hanák
TomD.inPDX
(To:torme)
Well, that's the default coordinate system for the academic version.
Funny how the default spin center symbol did not follow along.  Oversight by PTC?
In the commercial version, the center and the default coordinate system do agree.
