ModelCHECK, ModelUPDATE assigning material files from the library
jgraves
2-Explorer
Within ModelCHECK with ModelUPDATE enabled is there a way to have MATERIAL_INFO look within the root materials directory and the sub-directories within the root, for the .mtl file the user is trying to assign with ModelCHECK?
1 REPLY 1
molnium
2-Explorer
(To:jgraves)
I'm not shure about what to accomplish exactly,but you can set up ModelCHECK to check against a list of allowed material file names in the MCS files (MATERIAL_NAME ....) . Then if ModelUPDATE is enabled and no material file is assigned to a model, it seems that it does automatically assign the first material file that is on the list / or the first file in whatever sort order.... to the model.
greetings
In Reply to Joshuah Graves:
