ModelCHECK PARAMCHECK configuration question
kirk.wemple
Trying to set up ModelCHECK to add missing parameters to models that were not derived from our templates using the PARAMCHECK option in the .mch file. Works pretty well except I can't configure it to add a blank parameter. The best configuration I have now is to add a space to each missing parameter after the initial interactive check is done. Typical start file entry: PRT_PARAMETER MATERIAL STR. If ten parameters are missing the user has to enter a space for each and then click the Add button. Looking for any solution to avoid entering a space for each parameter. Just click the Add button and you're done. Any suggestions?
--Kirk Wemple
5 REPLIES 5
I believe you need a string that looks like this.
PRT_PARAMETER PREPARED_BY STR NEQ null
Note the "NEQ" rather than "EQ"
Bob Frindt
Sr. Designer
Parker Hannifin Corporation
Parker Aerospace
Gas Turbine Fuel Systems Division
9200 Tyler Boulevard
Mentor, OH 44060 USA
direct (440) 954-8159
cell: (216) 990-8711
fax: (440) 954-8111
www.parker.com
kirk wemple <->
05/03/2010 09:59 AM
Please respond to
kirk wemple <->
To
cc
Subject
[proecad] - ModelCHECK PARAMCHECK configuration question
--Kirk Wemple
Site Links: View post online View mailing list online Send new post
via email Unsubscribe from this mailling list Manage your subscription
Use of this email content is governed by the terms of service at:
Using MATERIAL STR NEQ NULL I still need to add a space in order to add the parameter.
If you want to be using the NULL value then your line needs to say "EQ NULL" rather than "NEQ NULL". Otherwise you are saying that the parameter cannot be
blank, which is what you are trying to avoid if I understand correctly.
Have you downloaded the help file on ModelCheck? It's all there if you spend
some time with it. Print it, make a binder and start adding your own notes.
ModelCheck is a great tool once you get it pass the users.
Curtis Odom
> cannot be blank, which is what you are trying to avoid if I understand
> correctly.
> *From:* kirk wemple [
ModelCheck is a good tool, but when will they update it? It sure could use a little TLC.
-marc
In Reply to Curtis Odom:
Curtis Odom
> correctly.
> *From:* kirk wemple [mailto:-]
> *Sent:* Monday, May 03, 2010 10:17 AM
> *To:* -
> *Subject:* [proecad] - RE: ModelCHECK PARAMCHECK configuration question
> parameter.
