Trying to set up ModelCHECK to add missing parameters to models that were not derived from our templates using the PARAMCHECK option in the .mch file. Works pretty well except I can't configure it to add a blank parameter. The best configuration I have now is to add a space to each missing parameter after the initial interactive check is done. Typical start file entry: PRT_PARAMETER MATERIAL STR. If ten parameters are missing the user has to enter a space for each and then click the Add button. Looking for any solution to avoid entering a space for each parameter. Just click the Add button and you're done. Any suggestions?
--Kirk Wemple
ModelCheck is a good tool, but when will they update it? It sure could use a little TLC.
-marc
In Reply to Curtis Odom:
Have you downloaded the help file on ModelCheck? It's all there if you spend
some time with it. Print it, make a binder and start adding your own notes.
ModelCheck is a great tool once you get it pass the users.
Curtis Odom
@On 5/3/10, Winter, Evan G <-> wrote:
> If you want to be using the NULL value then your line needs to say "EQ
> NULL" rather than "NEQ NULL". Otherwise you are saying that the parameter
> cannot be blank, which is what you are trying to avoid if I understand
> correctly.
> *From:* kirk wemple [mailto:-]
> *Sent:* Monday, May 03, 2010 10:17 AM
> *To:* -
> *Subject:* [proecad] - RE: ModelCHECK PARAMCHECK configuration question
> Using MATERIAL STR NEQ NULL I still need to add a space in order to add the
> parameter.
