ModelCHECK Status folder
Victor_Lopez
Hello!
I need some help about the MC configuration folders, for some constraints in the ProE configuration in my company.
I can not update the STATUS folder in the ModelCHECK CONFIG folder, so my question is
we have today in the condition file (status/status_old.mcq)
so the status_old.mcq is inside of theSTATUS folder.
but I need to modify the condition file to (new_status.mcq)
and the file new_status.mcq inside of the CONFIG folder.
is this posible?
I have made some tests and it seems to be working.
Thank you
Azael Lopez
2 REPLIES 2
Hi Azael,
You can set the location for the modelcheck files using the following in your pro/e startup bat file or system varible.
set MCDIR=C:\newlocations for modelcheck files\modelcheck
Hope this helps,
Don Anderson
You can also use the Creo config.pro option:
modelcheck_dir  : Specifies path to the ModelCHECK configuration files.
you can set it to a UNC file path in windows.  For instance:
modelcheck_dir \\<your server name>\<share name>\creo_settings\modelcheck\production\
Note: Creo looks for a folder called ‘config’ at the path specified in the modelcheck_dir option setting.  So be sure NOT to include ‘\config’ to the end of the specified path.
Best Regards.
