Modelcheck is DISABLED
LK_9769024
I am new in the world of modelcheck. I have read a bunch of articles about this theme on the creo support website, but still dont really know how to start this whole from the begining.
Firstly i have set my config.pro option yes for MC, and given a location for my MC optionfolder. Afterthat I have enabled MC at MC_ENABLED option, but still when I am trying to make an MC Interactive it sais that MC is disabled.
Thanks.
Levente
6 REPLIES 6
@LK_9769024
Which version of Creo you are working with?
Make sure you installed Creo ModelCHECK with Creo Parametric. It is available under Customize > Application Features > Check "Creo ModelCHECK.
@Mahesh_Sharma wrote:
@LK_9769024
Also, you have to check whether the license contains ModelCHECK module.
Martin Hanák
Firstly thanks for the reply.
I am working with creo 7, and i have also checked that my license contains modelcheck.
please attach picture showing how did you check the presence of Modelcheck license.
Martin Hanák
Set  config options as:
  • modelcheck_enabled YES
  • modelcheck_dir (point out towards your modelcheck directory)
Environment Variable (System Variable):
  • mcdir
    • the value must be the same as that of modelcheck_dir
Also, note that Creo will consider the directory mentioned in an environment variable.
