Modify component in assembly
ptc-3191571
I want to update component dimensions by linking it to a dimension created in assembly.
Like- I have part A which has extrude length of 100.I will add it in assembly then I have a dimension value called "Length" which is assigned to a datum then modifying this length value should update extrude in part A.
How do I link this.
0 REPLIES 0
