I need to create an assembly drawing of an assembly showing two different views of it in different states. There are componets in the assemlby which have two different positions. Theyare controled using a relation in a program. The mate offset value for the component constraint just has two different values, depending on which state it is regenerated in.
How would be the best way to get a view of each state in my drawing?
My first thought was to just double up on the componts that have different positions. Assemble them in both states and put them on seperate layers so they can be shown or hidden in the two views in the drawing. But I'm wondering if there is a better way. Anyone else create drawings like this with two different states like this? How do you do it?
Any thoughts or suggestions would be great, Thanks!
Ted
The easiest way I have found to do this is to place the "moving" component with mechanism constraints. Let it slide in the direction of motion. Create mechanism snapshots of the assembly with the component in both places and make them available for use on the drawing. This way you have no states, instances or any other overhead. My rule of thum has alway been:
If it is one deliverable thing but can move = Mechanisms
It can be serveral different deliverable things = Family table
If I want to simplify display of one deliverable thing = Simplified Reps
