This should be simple, I've got a large rectangular block (30" X 18" X 16") and I need to remove a lot of stock. The inner wall is at a 45 degree angle and goes down about 12". To save inserts on the 6" cutter I plan to use, I want to climb mill ALL the time! I made my incredibly simple volume, but can't find how to make the cutter start on the end of the block and step in to the 45 degree wall. Using TYP_ONE_DIR the first pass takes a full cut next to the 45 deg wall and then all the next passes convential mill to the end of the block. Thanks for any help Jon
