Need help modeling a space shuttle
ptc-4935373
https://docs.google.com/file/d/0B4dEiQq18yj2MVhsUGJlSUhmTkE/edit?usp=sharing This is what I have so far. I'm using Wildfire 5.0. I'm having trouble blending the nose to the fuselage and designing the wings. Any input would be appreciated.
3 REPLIES 3
I would think a sweep-blend would do well for the cab section. Use the tangency options to blend the sections.
How about an extrude of the wings with a few tappering cuts and a 3-surface round?
A blend will probably be the best method! See this tutorial http://learningexchange.ptc.com/tutorial/1612/creating-blends-by-selecting-parallel-sections
Yes of course, Tim is right, a simple blend is sufficient. We just had a long discussion on that very thing.
How to create a nozzle removing material with variable section sweep?
Some very good tips on how to make this work for you, Richard.
