I am currently working on creo2.0 .
Recently while working with drawings I need to adjust tables and notes to a specific position manually is there any other method I can move the tables and notes .
Try "Move Special". It is available for both tables and notes.
If you wanted to automate this you would probably have to develop some custom automation. Possibly a customized trail file would work, but most likely something with J-Link, VB API, SmartAssembly (3rd party), etc.
Thanks for the help TOM your help. Move special definitely works
