Need to adjust tables & notes using Co-ordinates
LuciferBV
I am currently working on creo2.0 .
Recently while working with drawings I need to adjust tables and notes to a specific position manually is there any other method I can move the tables and notes .
TomU
(To:LuciferBV)
Try "Move Special".  It is available for both tables and notes.
5 REPLIES 5
Dale_Rosema
(To:LuciferBV)
Ryan Kelley
I think this discussion needs to be moved.
Moved to PTC Creo‌.
TomU
(To:LuciferBV)
TomU
(To:TomU)
If you wanted to automate this you would probably have to develop some custom automation.  Possibly a customized trail file would work, but most likely something with J-Link, VB API, SmartAssembly (3rd party), etc.
LuciferBV
(To:TomU)
Thanks for the help TOM your help. Move special definitely works
