All
Not sure if this is 'intended functionality' but attached is a drawing view of a model created using a thin walled swept blend.
The view has been set to No Hidden but as you can see I am still able to view a lot of the hidden edges.
Any idea why this is the case?
Creo 2.0 m120
Neal
Just a quick update...thought if I made it completely solid and then shelled it I might get a better result, but no joy.
The attached image is completely solid part....this must be a bug?
All
For those that are interested I think I have found the problem...we have a config.pro option 'mesh_spline_surf' set to yes.
When I changed this to no it corrected the views.
