Note annotations
RonGrabau
8-Gravel
Note annotations
OK, I guess I am just not getting this but I cannot seem to get a note annotation to show on my model. I have no problems with dimensions, surface finishes, geometric tolerancesand symbols. I must admit that I must be missing something simple.
I am on Creo Parametric 2.0 M050. I don't think my platform makes any difference but I am running Windows x64. 32 Gb memory with an Nvidia 2000 graphics card.
When I go to the note creation, I can follow all the prompts. When placing the note, I get a bit lost. I have a annotation plane, I see that my cursor is changed to a note symbol but when I pick I see in the model tree that the note is there. I see in the dialog that I canunplace the notebut I cannot see the note. I have tried both with and without attachments without any luck.
In the model tree, next to the note name, I see a symbol that looks like a suppressed feature once I finish the feature. Right click revels nothing of note worthy help.
I know I amjust missing something simple so I am hoping that this group will point out my logicerror inthe steps I am taking.
Ronald B. Grabau
ME Applications Engineer
HP - Roseville CA
6 REPLIES 6
I know you're too smart to have a layer turned-off.
Got me stumped.
Joshua Houser
(have I talked to you about FIRST robotics yet?)
Pelco by Schneider Electric
Methods & Tools Sr. Engineer
Ronald,
Try setting the hidden config option Model_Note_Display to YES, Its set to
NO by default. I have no idea why it set like this.
Best Regards,
Jose M. Resendis
Mechanical & Optical Engineering Center (MOEC)
Raytheon - Space & Airborne Systems (SAS)
972-344-2555 office
972-979-5525 cell
"Great execution requires discipline"
JLG
(To:RonGrabau)
See Bjarne Frandsen's response to my question back in June -
llie
(To:RonGrabau)
Check your config.pro for what is new in Creo 2 compared to your previuos
build that you had installed. I always do a spread sheet comparison of all
the config options between my production build and future build. I believe
you are looking for this:
display_annotations yes
Lance J Lie
Information Technology
SAS IT Info. Solutions App. Eng.
Space and Airborne Systems
Raytheon Company
+1 310.616.1551 (office)
+1 310.426.4968 (cell)
+1 310.647.0315 (fax)
2000 E. El Segundo Blvd.
El Segundo, CA 90245 USA
www.raytheon.com
Raytheon Sustainability
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this
message in error, please so advise the sender by reply e-mail and delete
this message. Thank you for your cooperation.
TomU
(To:RonGrabau)
One other nuance. If you're using Standard Hole Features, their notes will not show up (regardless of the 'Annotation Display' setting) unless you first "Show" them using the "Show Annotations" tool.
Tom U.
Thank you so much for the quick replies. The answer is to turn on the hidden configuration file option: model_note_display YES
Ronald B. Grabau
HP PDE-IT
Roseville, CA
916-785-3298
-<">mailto:->
