Note color in pvz export
ZC_10909252
I have many users that use the Dark theme in Creo parametric 9. The note color is yellow for that theme. When exporting to a PVZ the text color is also yellow. How can I change that so they can keep the dark theme and export the note text to black or whatever preferred color?
I tried changing the the system_colors_file to C:\Program Files\PTC\Creo 9.0.3.0\Common Files\text\system_colors\light.scl but that did not resolve the issue.
Hi @ZC_10909252,
Thank you for your question! I am replying to raise awareness. Hopefully, another community member will be able to help.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
Please refer to this guideline to make your questions more likely to receive a quick and useful answer.
Thank you for your participation!
Catalina
PTC Community Moderator
PTC
