Offset surface up to a datum point?
David_M
Does anyone know of a reasonably quick way to offset a complex surface up to a point rather than by a value? Naturally only one point on the surface would be at the specified point after the operation.
4 REPLIES 4
You might have to use a relation.
dgschaefer
(To:David_M)
Create an analysis feature to measure and capture the distance from the point to the surface then set the offset to be equal to the measured distance.
LinkedIn
David_M
(To:David_M)
Thanks for both your replies. The I need to offset by a negative value and the offset feature does not allow for linking to parameters with negative values.
You can maybe use the Absolute Value relation. I forget the syntax.
