Open Solidworks drawing in Creo 1?
JoshH
Hi folks,
I have a seat of Solidworks 2012 and Creo 1.
I attempted to open a Solidworks drawing with no luck.
I can open a Solidworks part without a problem.
Anybody else able to open a Solidworks drawing in Creo 1?
Josh
3 REPLIES 3
VladimirN
(To:JoshH)
Hello!
Joshua Houser wrote:
...Anybody else able to open a Solidworks drawing in Creo 1?...
Could you provide SolidWorks example?
JoshH
(To:VladimirN)
Solidworks.zip
Hi Vladimir, attached is a simple Solidworks part and drawing I created for testing.
VladimirN
(To:JoshH)
Creo Parametric 1.0 (and Creo/Elements Pro 5.0) can open only two types of 3D models from SolidWorks - assembly (".sldasm") and part (".sldprt"). To view drawings (".slddrw") created ​​in SolidWorks, you can use a free viewer "eDrawings": http://www.solidworks.com/sw/support/downloads.htm?cid=hp_tab_support_downloads
Also you can save drawings in "DWG" format, which can be opened in Creo Parametric 1.0 (and Creo/Elements Pro 5.0).
