Ordinate Dimension Cleanup
ptc-1868133
When using ordinate dimensions to detail relatively close features, the dimensions show up overlapping each other. Is there a way to have ProE automatically add a jog?
I found an old post from 2007 with the same question, but no replies. Hopefully that isn't an ominous sign...
mlocascio
(To:ptc-1868133)
That's a good question.
My personal experience would normally tell me "no" but there may be a way to
tag a set of dimensions, or a view and do a dimension cleanup.
Michael P. Locascio
If you use the auto-create ordinate dimension feature it will auto jog the
dimensions that will overlap, you will have to go through and delete extra
ordinate dimensions that you probably don't want but it will be easier
once you get used to it.
Brian S. Lynn
Technical Coordinator, Product Engineering
This subject has made me curse for the past 10 years since switching to Pro... I've complained about the usefulness of a clean-up tool for ordinate dimensions at user group meetings to the PTC reps...I'm pretty sure that was in one ear and out the other. Detailing drawings doesn't seem to be a big concern of PTC. mb
The regular Dim Clean Up tool works on Ordinate dimensions, do you not get
the results you want?
Also there is less clean up if you use the auto ordinate dim tool, but yes
there is still quite a bit.
Merry Christmas & happy holidays,
Brian S. Lynn
