PDF Setting - Right Monitor
Dale_Rosema
Not necessarily a Creo issue, but with Acrobat Reader, does any know how to have the .pdf always open on the secondary monitor?
Dale_Rosema
(To:Dale_Rosema)
I don't have the exact details and I'll try and post them the next time our IT guru stops in.
In windows, use PowerToys. Go to settings and then set up FancyZones. Once the zones are set up.
Take the first instance of the application that you what to move/setup and Shiftkey-Drag the application to the desired FancyZone.
All others with then open up in that FancyZone.
(Periodically my FancyZones have turned off and I have to do it again.)
2 REPLIES 2
Dale_Rosema
(To:Dale_Rosema)
In Full Screen, it has Which Monitor to use:
But the options are:
This Monitor
Best Color
Widest
Tallest
Biggest
Main.
If you drag the Preference page to the second monitor, This Monitor still is the first monitor.
Dale_Rosema
(To:Dale_Rosema)
