Posted: Wed Sep 09, 2009 12:40 pm Post subject: PDF problem:
Another approach is to leave the part number alone, and add a description field. Our example here is CPVC pipe spools. CPVC has one part number, regardless of the spool size. So we added a description parameter and in that field we give each spool a number. ie: 4" CPVC SPOOL 1, 2, 3 etc. Then in your BOM each piece will show up, with the same part number but as a separate line item due to the description field.
Just another thought.
Chris BennerAnother approach is to leave the part number alone, and add a description field. Our example here is CPVC pipe spools. CPVC has one part number, regardless of the spool size. So we added a description parameter and in that field we give each spool a number. ie: 4" CPVC SPOOL 1, 2, 3 etc. Then in your BOM each piece will show up, with the same part number but as a separate line item due to the description field.
Chris Benner
Designer II
Powell Fabrication & Manufacturing, Inc.
<u></u>Chris,
We DO have a description field, it's just that since we do a lot of weldments, many times the description is just "TUBE" or something. and, if there's nothing else to sort by (&asm.mbr.name), everything that simply says "TUBE" ends up in one row.
