PTC_CONSTRAINT_SET
Himanshu
PTC_CONSTRAINT_SET
How to work with an assembly using PTC_CONSTRAINT_SET in relation and parameters.
Thanks for assisatnce :). I will try from my side.
4 REPLIES 4
I prepared test models in Creo Parametric 2.0 M070. See attachment PTC_CONSTRAINT_SET.zip.
In both cases you can set assembly parameter POSITION to 1 or 2 and regenerate to see the effect.
podsestava1.asm ... relations are defined on component level
podsestava2.asm ... relations are defined on asssembly level
Martin Hanák
Can record and provide me the video how to do it ?
I am sorry I do not have enough free time. Please open assembly and investigate parameters and relations. It is not complicated action.
Martin Hanák
