Part Feature driven by assembly datums
Hi.
In its simplest form, what I am trying to acheive is to have a datum plane in an assembly drive the position of a datum in parts.
Lets say I create a datum 200mm from the default top datum plane in the assembly and call this ASM length.
If I then create a part and constrain this part in the default position in assembly. I create a datum plane in the part called PRT length.
I want to the position of PRT length to be equal to the ASM length ( 200mm).
So when I create a family table of the assembly, each instance will have a different value for ASM length.
I intend to have multiple parts in the assembly all having the Part length datum controlled by ASM length.
In its more complex form each part will have feature positions driven by the assembly datums.
Which is the best approach to acheiving this outcome?.
Thanks for your help in advance.
